preping and engine.
Old Jul 16, 2007 | 07:28 AM
blackbyrd's Avatar
Default preping an engine.
had a 414 built based off the 6.0l iron block and its been setting for a while (close to a year) but as it approaces time to fire it up. i was wondering what steps should be taken as a precaution or things i would need to do to the internals before it is started for the first time?? obviously it will need oil but should i take the pan back off and make sure the crank is covered well with lube before the initial start up.
Old Jul 16, 2007 | 11:46 AM
Ferocity02's Avatar
Was it built with assembly lube? Has it been ran since being built? If it's yes and no, then I'd just fill the engine galleys with oil and start her up. Do this by pouring oil into the oil pressure sending unit hole in the back of the block behind the intake.
Old Jul 16, 2007 | 01:46 PM
WE TODD DID's Avatar
Disable the fuel, and ignition systems. Then, spin the engine over with the starter for a bit so it will be primed. After that, you should be ready to go.
Old Jul 16, 2007 | 01:51 PM
sroach20's Avatar
disconnect the two coil harnesses (big white plugs in the center of the coil brackets) on each side. press the gas pedal to the floor (gives the flood command to stop the injectors)and crank for about 4-5 seconds. plug coils back in and your done.
Old Jul 16, 2007 | 01:54 PM
3.4camaro's Avatar
pull the fuel pump fuse and the ignition relay.
crank for 10 seconds
wait 10 seconds
crank 10 seconds
wait 10 seconds
crank 10 seconds
plug the fuse and relay back in
fire it up
I did this last week with my new H/C setup and it fired up with within 3 seconds with 60lbs of oil pressure at idle!
Old Jul 16, 2007 | 02:00 PM
sroach20's Avatar
why pull the fuel pump fuse? if you hold the gas pedal to the floor, it will give the computer a flooded signal and tell the injectors to not fire.
Old Jul 16, 2007 | 02:15 PM
blackbyrd's Avatar
yes it was built with assembly lube or atleast thats what im guessing it was it was almost a greenish oil. but no it has never been started. i wanted to ask on here cause i asked a friend who was into rebuilding cars and i was told to put marvel mystery oil in the cylinders and hand turn them couple of times then hook it up to a starter to pump the oil out
Old Jul 16, 2007 | 02:19 PM
blackbyrd's Avatar
even if its been setting almost a year thats all i need to do?
Old Jul 16, 2007 | 05:27 PM
Ferocity02's Avatar
Well assembly lube sticks around for awhile, so the bearings should still be lubed. I'd just fill the galleys and start her up. Some of the oil will seep out into the pan between filling the galleys and starting it, but the galleys won't be empty, so you will have pressure in a couple seconds. This is what I did, and I had pressure in one second without any priming.
Old Jul 17, 2007 | 12:52 PM
blackbyrd's Avatar
the galley's??
and what woudl you do different if there was no assembly lube?? just out of curiosity
