L19 Head studs
Old Jul 17, 2007 | 09:51 PM
Firehawk853's Avatar
Default L19 Head studs
I'm looking for a set, L19 head studs, LQ9 6.0L block,
do any of the sponsors have a set in stock? If not where can i get some on short notice? pretty please?
Old Jul 17, 2007 | 10:26 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I called ARP about this a while ago about these. They said that they are special order only and don't carry a part number. You have to specify what you are using them with. The tech told me they are $435 and their number for the specialty shop is 1-805-525-1497. I don't know how long they take to make them or if they have any in stock, but just give them a ring.
Old Jul 18, 2007 | 12:52 AM
DONAIMIAN's Avatar
How much power are you making to justify that kind of bolt?
Old Jul 18, 2007 | 06:53 AM
It is probably in the high 800 range. Havn't been able to get a dyno pull on it yet. It lifted the heads on the first WOT pull.
6L Iron block
AFR heads
F1C blower
8.6:1 compression
I"m also going with a thicker gasket to get the compression down near 8.3:1 or so.
Old Jul 18, 2007 | 04:15 PM
OWN3D BY MY PROF!
I think your compression is fine. What head gaskets were you running?
Old Jul 18, 2007 | 04:24 PM
SCE copper O-ringless.
I will be switching back to Cometic MLS.
