help with supercharged lq9
Old Jul 19, 2007 | 08:28 PM
sc-silverado ss's Avatar
Question help with supercharged lq9
I have Supercharged 05 SS Silverado it is a stock lq9 with 6# boost
iwant to safley up the boost to 14ish and make good use of it
so what i needto know is what would be the best setup to go with as far as
. camshaft
. pistons/rods
. heads
. intake/injectors
. compression ratio
any help would be usefull thanks
Old Nov 20, 2007 | 08:37 AM
udlose99ta's Avatar
i guess better late than never,
stock cams work well with boost but if your gonna tear the engine apart why not throw one in right? I dont know about the rods but i know the pistons will need to be forged and dished to lower the compression on that lq9. You could just find a cheap set of lq4 pistons (someone would probably just trade you) and have a very cheap 9:4.1 engine. i would think that would hold 10-12 lbs but im no expert
