oil pump install question
Old May 15, 2003 | 09:44 PM
NiceTry's Avatar
Default oil pump install question
i am installing a cam and while i am in there i want to replace my oil pump. i was wondering how you disconnect the pickup tube from the pump. do you have to drop the oil pan a little for it to come down or drop the pan completely off?
Old May 15, 2003 | 09:54 PM
MOBE's Avatar
Default Re: oil pump install question
You can't take the pan completelt off with the engine in the car, I believe. Go to, www.ls1howto.com/?article=2 Scroll down to the part about the oil pump install. This should answer your questions.
Larry's Avatar
You do have to drop the pan about 1/2" or so. That's about all it will drop before contacting the K member. There is one bolt holding the oil pump to the tube. Remove that bolt carefully to insure you don't drop it into the pan. Might put a rag under the bolt to catch it. I was able to get my fingers to the bolt once I had it loosened with an end wrench.
The back two bolts in the pan require much less torque than all the rest. Don't strip them.
Old May 15, 2003 | 10:04 PM
NiceTry's Avatar
thanks for the input, it's just the short block sitting in the car right now to i figured if i need to do any raising up now would be the time
