can you install a cam off even thoe it dot to dot
well im thinking in my head about a cam swap.
the valves are all held up but the springs. whern you turn the crank to get the dot up and put the cam in and line it up how do you know what piston is up or down? does any one know what im thinking about? how do you know what piston is up when the the dot is up? or is the same piston up the same time as the dot.
sorry nube queston
sorry nube queston
Originally Posted by bad6as
same with the cam? when the dot is down the same lobes will be in the same place?
