OOOPS lifters
Old May 17, 2003 | 11:02 AM
BYBYC5's Avatar
*Bad Trader*
Default OOOPS lifters
..i forgot to saok the lifters in oil befor in put the heads back on, now the rockers are kinda mushy( i can push in a little on the pushrod side) will they pump up after i fill the engin with oil and let it idle for a while. i reallly dont want to have to take off the heads......
Old May 17, 2003 | 11:14 AM
Tin Indian's Avatar
Default Re: OOOPS lifters
They sure will pump up.
If I were you, I would pull the PCM IGN and the Fuel Pump fuses. Then crank the engine for a couple of minutes. You will see the oil press. come up on the guage. Again, let it crank for awhile. Put the fuses back in. You should have no problems...
Ron,
Old May 18, 2003 | 01:14 AM
NiceTry's Avatar
yeah they'll pump up
