max rocker ratio with setup?
Old Jul 24, 2007 | 05:50 PM
dlove's Avatar
Default max rocker ratio with setup?
im running 241's that are milled .030, with a comp 224/228 .534 .537.
what is going to be my max ratio of aftermarket rockers that i can go with? I can get a good deal on some comp pro mag 1.75s. Does anyone have any input on those rockers?
thanks,
Old Jul 24, 2007 | 07:23 PM
JPH's Avatar
JPH
crane 1.8's quick lifts would work perfect with that camshaft. giving you more valve lift both int/exh in the .565-.570 area, and adding more valve duration to your camshaft.
Old Jul 24, 2007 | 07:35 PM
Randy WS6's Avatar
I run the comp 1.75 roller rockers very nice rocker arms
224/228-.550/.553 your lift ,if you use the Comp Cam 1.75 roller rocker.
Old Jul 24, 2007 | 07:41 PM
vettenuts's Avatar
Even the Crane 1.7's are 1.72 when fully open. If you are looking for a difference I would look at the Crane 1.8's otherwise it may not be worth the money.
Old Jul 24, 2007 | 07:48 PM
chriswtx's Avatar
I have the comp pro mag 1.75s in my car. I love them..If you can good deal on some comp pro mag 1.75s run them..
Old Jul 24, 2007 | 10:33 PM
dlove's Avatar
sweet thanks for the help guys, keep the comments coming
