smoke!
Old Jul 26, 2007 | 10:00 PM
qwikz28's Avatar
Default smoke!
and lots of it! i just finished heads/cam on my car (torquer 3) and it is still untuned. now this car shoots out ridiculous amounts of smoke! is this normal? the smoke has a whitish/blue tint to it.... if this is normal, will it be fixed once i'm tuned? thanks guys
jacob
Old Jul 26, 2007 | 11:30 PM
BerryWS6's Avatar
yea I have the same thing. I changed the vavle seals and it did nothing. did not smoke before heads.
So I am in the same boat as you and would like to know this as well. My car is going to get tuned in about 2 weeks and get 38# injectors.
Old Jul 28, 2007 | 12:39 AM
qwikz28's Avatar
no one drove a cammed car without a tune before and can tell me if they experienced this? just wanna check if something is wrong before i put it on teh dyno
Old Jul 29, 2007 | 11:37 PM
Mustang Hat'r 2's Avatar
Get rid of your PCV system or put a catch can on it. You pulling oil through PCV system into the intake.
Old Jul 30, 2007 | 12:41 AM
Blk97WS6's Avatar
Sucking oil threw the intake would not cause white smoke. If it was burning oil, it would be black. Hate to say it but white is usually coolant.
I had stock heads on mine, but i know after my cam swap, before the tune the car didnt smoke that bad(but i never went WOT until after the tune).
A quick way to check the PCV anyway would to just pull of the lid and MAF off, crack the throttle body, and peak in there with a flashlight to check for a bunch of oil residue.
Old Jul 30, 2007 | 08:26 AM
qwikz28's Avatar
the smoke is black, not white. i'll check the intake for oil. it was a new intake so it shouldn't be too hard to locate. my next question is, would a catch can fix oil in the intake if that were the case? i have a breather that i haven't installed yet, would that help? (besides the fact that it looks cool )
Old Jul 30, 2007 | 12:15 PM
Blk97WS6's Avatar
A can catch will solve the problem if its getting in threw the PCV system, which is a VERY, VERY common problem with ls1's. I installed a catch can on my car, and had no problems burning oil ever since.
Since you installed new heads, im guessing the valve seals are new, so more then likely you ARE burning oil threw the intake.
Old Jul 30, 2007 | 02:12 PM
White smoke is coolent
White/blue smoke is oil
Black smoke means your rich as hell
First post states blue smoke, that is oil. I had that after the cam install the catch can fixed it.
Old Jul 30, 2007 | 04:14 PM
qwikz28's Avatar
confirmed i'm burning oil due to a mist of oil covering the rear bumper of my car thanks guys, i'm ordering a catch can as we speak.
