New Cam and oil pump problems
Also, I changed to a LS6 oil pump and my oil pressure went down. Is this normal?
As for the oil pressure, not sure. (I hate to suggest the classic O-ring problem because every post mentions it lately!)
Tommy
As for the oil pump, my car started out at 60psi @ idle when I bought it, and it slowly dwindled itself down to about 40psi @ idle (when warm) throughout the break in. When I did the cam I swapped out to a katech ported unit and the pressure stayed the same. 10k miles later I still see about 40psi at a warm idle, 55-60psi under cruising, and maybe 70-75psi under WOT.
As for the hesitation.. this happened right after I put in the new cam. My last cam did not do this so I figure it had something to do with this certain cam. I can see how you would think it was the clutch... however, my car is an automatic and it is tuned. Anyone else have a suggestion?
