hole in intake port on head
Old May 19, 2003 | 03:55 PM
99 TA's Avatar
Default hole in intake port on head
I never really looked at the heads before but when I got them back from Absolute Speed I noticed that every intake port had a hole in it where the rocker bolt comes down through. Is this supposed to be like this? The heads flow good though.
Old May 19, 2003 | 04:01 PM
LARRY01Z28's Avatar
Default Re: hole in intake port on head
yep, and once you get them on there will be a little bit of the bolt sticking out there also.
Old May 19, 2003 | 04:09 PM
jmX's Avatar
jmX
Yes, that is normal. Put a little locktite on the intake rocker bolts when you put them in. It'll kinda act as a sealant to keep oil from dripping down through the threads and into the intake.
Old May 19, 2003 | 04:12 PM
99 TA's Avatar
Thanks. I feel a lot better now. Just got to get these bad boys on now.
Old May 20, 2003 | 01:22 PM
robertbartsch's Avatar
Yeh; my ported LS6 heads look the same...
Old May 21, 2003 | 06:21 AM
Tin Indian's Avatar
All of my intakes look like that on my 5.3L heads. TEA recommends applying black silicon sealant to the intake rocker bolt threads prior to installing.
