Aftermarket rod length?
If you use stock CH pistons and the 6.125 rods (vs 6.098) the tops of the pistons willbe .027 higher than stock. That may be a big problem. Your engine designer/builder will advise you as to where the piston should be.
Jon
It is not only a matter of deck height but pin location.
When choosing piostons use recomended rod length, most are built for 6.125 size.
Last edited by PREDATOR-Z; Aug 3, 2007 at 09:59 AM. Reason: sorry, edited insted of quoting LOL
