heads on a trex...
Old Aug 5, 2007 | 09:16 PM
The PAT WS6's Avatar
Default heads on a trex...
i was gonna go with some ls6 ported heads or something... as long as i dont get them milled and use the stock gaskets would everything be ok?! wat othr heads would u guys recommed i know the cars out there with the trex and heads are makin some sick numbers so post it up...
Old Aug 5, 2007 | 09:30 PM
05 GSXR 1XXX's Avatar
get some ls6 heads from TSP. i just spent the last 20 min watching your vids, theres a lot of t/a around you lol
Old Aug 5, 2007 | 09:35 PM
**** and *** or trans am?
Old Aug 6, 2007 | 12:21 AM
PREDATOR-Z's Avatar
The only heads that would work without flycutting are either stock or LS6/LS2 unmilled with stock valves and gaskets.
Stage 1 heads.
Old Aug 6, 2007 | 08:56 AM
venom ws7's Avatar
Get TSP PRC Heads my friend Caprice SS Ran 11.2 with that setup 4 doors LS1
Another friend have them with MS4 The car pulls like friggen train.
Those heads give friend of mine 39rwhp and 29rwtq just from heads swap no BS Here.
check this
http://www.youtube.com/watch?v=tYN46ZXIUYY
Old Aug 6, 2007 | 05:22 PM
ya i knw i have to go with the ls6/ls2 how much should i get them ported. and will my valves from my 853's work on them becuase i already have the patriot extreme springs with everything...
Old Aug 6, 2007 | 10:09 PM
will stock 317s work?
Old Aug 6, 2007 | 10:18 PM
heavy6.0's Avatar
the prc stage 1's are fairly inexpensive for what they flow and you might as well do a ms3 or ms4 while your there. I made 473rwhp with a sky high idc at 117%. so they make good power. just my 2 pennies.
Old Aug 6, 2007 | 11:39 PM
hammertime's Avatar
Stock 317's should work, but you'll lose a lot of compression, not a good idea with that cam. You would give up a lot of low-end throttle response.
AFR 205 heads have a greater valve drop, even milled to 59cc, than stock 241 heads. Louis from LG Motorsports has posted this on more than one occasion in reference to installing G5X3/4 cams with heads. If you could swing a set of those, and run some .040 gaskets, you should be able to squeak by (but still check!!!) PTV clearance. If cutting is required, it will be a great deal less than a stock casting would require, milled to the same cc's.
Old Aug 7, 2007 | 01:58 AM
anything else? i should probably just go with a set of 243's with a port job maybe later...
Old Aug 7, 2007 | 02:45 AM
NOS USER's Avatar
TFS Heads
Old Aug 7, 2007 | 09:12 AM
venom ws7's Avatar
The PRC Head are very cheap and you can get them without the Springs man believe me you wont be sorry buying those $1049 Ported and with comptition CNC Valve jop.
Good luck and like been said before those 317 are not worth the heads swap.
Old Aug 7, 2007 | 11:18 AM
i cant afford to go with new heads from a sponser with a port job cnc that and this, for now im buyin stock heads.
i e ls6, ls2 etc etc.
wat is with these 317's? will they bolt on how are they with a cam only setup cus i knw alot of people are runninght them on FI setups
Old Aug 7, 2007 | 11:53 AM
PREDATOR-Z's Avatar
317 are 72cc (too big)
stick with LS6/LS2 243 casting.
Old Aug 7, 2007 | 12:32 PM
ok thanks for answering my question.
should i not even mess with going with a bigger gasket to clear the PTV w/317's...'
now with the 243's how much for a good port job, down the road?
Old Aug 7, 2007 | 12:40 PM
Raven02TA's Avatar
check this
X2 to the PRC heads. you'll be happy with the stage 2.5 heads. I have been running 11.2's N/A all day foot braking the car and i also have a TREX cam.
Old Aug 7, 2007 | 12:42 PM
jesus christ man, are you pullin them numbers with those heads?!?! what else do you have on the car?
Old Aug 7, 2007 | 01:31 PM
Raven02TA's Avatar
that was launching at 3800 RPM on the foot brake. forged internals/trex cam/PRC stage 2.5 heads/Neal Chance 4000 stall/TH400 (now with a brake)/4.11 gears/lot of suspension work.
Old Aug 7, 2007 | 01:37 PM
no the 508 521. how much were ur 2.5L heads and what is the casting number on them.
Old Aug 7, 2007 | 02:10 PM
Raven02TA's Avatar
the 508 hp / 521 tq is the same set up. only with 100 shot of spray (mustang dyno numbers). (with dynojet numbers its 558.8hp and 573.1tq)
