Shortblock assembly....do you have any input?
Old May 21, 2003 | 04:52 PM
Phil99vette's Avatar
7 Second Club
Default Shortblock assembly....do you have any input?
I picked up everything to build my shortblock about 30 minutes ago. I am going to start tomorrow afternoon when I get off of work. If you have built a shortblock and have any tips or things you learned your input is welcome. Maybe this can help others in the future...
Topics:
1) Cleaning Block
2) Clearance for Bearings
3) Ring Installation
4) Wrist pin Installation
5) Crank Installation
6) Piston Installation/Bore preperation
7) Torque specs
8) covers and gaskets
Phillip
Old May 21, 2003 | 05:03 PM
strokedls1's Avatar
Default Re: Shortblock assembly....do you have any input?
Clean the block meticulously before you start installing anything. I like to plastigage all the mains and rod journals. Pin installation will vary with different companies. Silicone on the front and back of the oil pan gasket. I like to torque the head bolts to 70 ftlb for the big ten, and 25 for the small top ones in the gm specified order. LS1.com has a list of all the torque numbers and sequences, as well as jmx website. Rings just need to be filed before you install them. Again the piston manufactuer should of given you the gap numbers for N/A, nitrous and sc applications. Don't forget the rear oil plug or you won't have oil pressure. Spacers can be used on the rockers to get the right preload on the lifters. That is all that comes to mind off hand.
Old May 21, 2003 | 05:46 PM
7 Second Club
I'll add my .02
1) Cleaning Block
Block should be cleaned with soap and water. Dry quickly with filtered air and lint-free cloth.
Bearings should either be checked with plastigage or measured with spring bore calipers and a micrometer. Lube with assembly lube for final fit.
Rings need to remain flat to ensure they dont break, ring expander makes much easier.
Whats the easiest way to install the spiral clip?
Lube the rings with 30wt oil and coat the more with oil as well to lube the hatches for inital startup. Rods are installed with round edges to the outside of the journals and valve reliefs on the top.
7) Torque specs
Head studs:
ARP studs and lube 25/50/70, 25 on small ones
Phillip
Old May 22, 2003 | 01:22 AM
Hawk's Avatar
what kinda connecting rods will you be using?
take your time and recheck everything inside.
Old May 22, 2003 | 08:06 AM
7 Second Club
Eagle H beam's.
Phillip
