how to clean a cam ?s
I dont really know. I didnt wanna do anything abrasive unless I was positive it would be ok like steel wool or anything. Maybe just some lacquer or like you say some brake cleaner
Just in case you get there and dont really know, white scotch brite is finer then gray and red scotch brite. I use white scotchh brite to fine polish anything from metal to acrylic countertops.....
Just clean it good afterwards, the Scotchbrite will leave small pieces behind when you use it. Give it a good flush with brake cleaner including the hole down the center if there is one then coat with oil.
