Need some advice...snapped a ring..
Old May 22, 2003 | 06:29 PM
Phil99vette's Avatar
7 Second Club
Default Need some advice...snapped a ring..
Well when I went to install my #8 piston apparently the ring wasn't seated correctly so when I tightened the ring compressor the 2nd ring snapped. Any ideas on easy solutions?
Phillip
Old May 22, 2003 | 06:32 PM
Country Boy's Avatar
Senior Member
Default Re: Need some advice...snapped a ring..
the only solution there is..... buy another one.
Old May 22, 2003 | 06:37 PM
7 Second Club
Can you just buy one pistons worth of rings?
Old May 22, 2003 | 07:21 PM
Senior Member
it depends on whos rings they are. Youll need to contact them or your shop that you got them from and they can find out.
Old May 22, 2003 | 07:54 PM
T/A Medic's Avatar
also u might have to file the rings...
i have 7-2nd rings left for Diamond Pistons because I had that exact problem, same pistion too wtf over!
Old May 22, 2003 | 09:43 PM
66ImpalaLT1's Avatar
Did this on the first SBC I built, sucks but it happens.
