No oil pressure!!!
Old Aug 12, 2007 | 08:32 PM
01BlackCamaroSS's Avatar
Default No oil pressure!!!
finished my heads install and when we started up the car the oil pressure would not build up at all what could be the problem
Old Aug 12, 2007 | 08:47 PM
98Camarod's Avatar
Did you install a new oil pump?
Old Aug 12, 2007 | 09:07 PM
nope that was done back in april wiht my cam install
Old Aug 12, 2007 | 09:17 PM
98Camarod's Avatar
If you didn't mess with that, I don't really see a reason why you wouldn't have oil pressure. Is your sending unit broken or not connected?
Old Aug 12, 2007 | 09:26 PM
where is it located at im trying to find it
Old Aug 12, 2007 | 09:30 PM
98Camarod's Avatar
It's behind the intake manifold, it stands straight up.
Old Aug 12, 2007 | 09:31 PM
can you get to it with out taking the manifold off
Old Aug 12, 2007 | 09:35 PM
98Camarod's Avatar
You should be able to reach back there to see if its unplugged, but it would be hard to tell if it is broken though unless its hanging there.
Old Aug 12, 2007 | 10:24 PM
thanks man for all your help it is the oil pressure sending unit but other than that the install seems like it went really well no leaks that i can see or any breaks just need to get the car tuned again
Old Aug 12, 2007 | 10:39 PM
98Camarod's Avatar
So it was unplugged then?
Old Aug 13, 2007 | 03:58 AM
DaddySS's Avatar
Good call!
Old Aug 13, 2007 | 02:07 PM
no it wasnt unplugged it was broken
