TSP can you please chime in? I need your help!
Old Aug 13, 2007 | 04:46 PM
regorih383's Avatar
Question TSP can you please chime in? I need your help!
Well I have a set of your Terminator 200cc heads milled down to 59cc and im running a 228/228 .579"/.579" 114+0 cam. Can you tell me what push rod I should run? The reason I ask is because I have a new set of harden push rods from another project that I never used but, they are 7.350 long, can I used these????
Thanks
Roger
Old Aug 13, 2007 | 04:55 PM
SHINER's Avatar
i would stick with a 7.400 pushrod.
Old Aug 14, 2007 | 04:03 AM
playtoy's Avatar
With that cam and the heads milled to 59cc the 7.400 will probably be fine but you should check them out when you put them in. Make sure the tip of the rocker isn't rolling of the valve stem.
