Lifter Question
Old Aug 14, 2007 | 03:01 PM
SPG's Avatar
SPG
Default Lifter Question
after installing new heads, I checked the rod length required with the rod length tool, added a preload of 60 thou to get a rodlength of 7.375.
these are stock SBC lifters, not the ls1 ones. the lifters have been in the engine running,
When i torque the rockers in to 22, i see each spring on the head compress a little. (some more than others if the cam is on the lift) perhaps 2mm
is that corrrect. I thought the preload would see the lifter compress a little, but not the valvesprings
am i just wrong........
Old Aug 15, 2007 | 03:41 AM
SPG's Avatar
SPG
ttttttttttttttttttttttttttt
