Allenhead bolt on 243 heads
Old Aug 14, 2007 | 06:59 PM
houseylou's Avatar
Default Allenhead bolt on 243 heads
Where is the bolt located on the head? I need to remove it and wrap it in teflon tape b/c i think it's leaking coolant. Is it on the back of the head somewhere?
Old Aug 14, 2007 | 07:03 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
Back of the passenger side head. above number 7 cyl
Old Aug 14, 2007 | 07:10 PM
houseylou's Avatar
oh there's only one? well i thought the leak might have been coming from the driver's side...so i hope it's not something too serious. maybe a head gasket at worst case.
Old Aug 14, 2007 | 07:11 PM
ALLBOTTLE's Avatar
LS1TECH Sponsor
on the driver side you have the coolant temp sensor.
You can also check the coolant cross over tube or the block of plugs to see if they are tight.
Old Aug 14, 2007 | 07:23 PM
houseylou's Avatar
okay cool. when i attach the coolant hoses again i'll make sure they're on tight. thanks.
