View Poll Results: tsp stage 2.5 5.3 or tsp sage 1 ls6 for the tsp 233/239
5.3
25
45.45%
ls6
30
54.55%
Voters: 55. You may not vote on this poll
tsp 233/239
Old Aug 17, 2007 | 04:20 PM
BYE RICE's Avatar
I used the standard 113 LSA..Worked fine..It had a nice thump.
Old Aug 17, 2007 | 04:29 PM
98NATA's Avatar
Not to hijack, but your saying i cant use this came with my stock 98' heads?
Old Aug 17, 2007 | 04:54 PM
BYE RICE's Avatar
I did..Well..they were milled & ported with bigger valves.
So all you need is a set of PRC duals or 921 type springs.
Old Aug 17, 2007 | 04:58 PM
Nimitz87's Avatar
buddy has that cam with the PRC 5.3 stage 2 heads and made 425rwhp on a mustang dyno and traps 119 in the 1/4.
Chad
Old Aug 17, 2007 | 05:47 PM
BYE RICE's Avatar
Originally Posted by Nimitz87
buddy has that cam with the PRC 5.3 stage 2 heads and made 425rwhp on a mustang dyno adn traps 119 in the 1/4.
Chad
Nice trap speed..
I happen to like my 5.3 2.5's as well.
Old Aug 17, 2007 | 06:18 PM
white_camaro's Avatar
that is a nice trap speed. my 233/239 is on a 114 lsa and i installed it dot to dot. its got 8 degrees of overlap and is pretty lopey but i wish i would have gotten on a 113 or 112. I shift at 6500, limiter set at 6800.
Old Aug 17, 2007 | 06:37 PM
Nimitz87's Avatar
Originally Posted by BYE RICE
Nice trap speed..
for what the 5.3 heads are they are awesome middle of the road heads that perform great, and the guys at texas speed are top notch to deal with
I wouldn't hesitate to go with their 233/239 heads cam package w/ the 5.3's....
Chad
Old Aug 17, 2007 | 08:58 PM
Dragkid1917's Avatar
i wonder if i hook with that cam setup, the 3.73's and the ss3600 if im gunna start breaking stuff...
Old Aug 17, 2007 | 11:57 PM
Irocss85's Avatar
you should be doin 1.6's with that setup if you can hook. if I can hook up mine, you shouldnt have a problem either. with 17" drag radials I hook very well. no problem. same 3800 stall, prolly just a little less HP then that setup will make in your car. but Im sure my cubic inch's will give me more low end torque. anyways, sorry, but the rear gear will be hit or miss. some last long time at these time's/power level, some dont last long at all. I'd bet the 3:73's wont last, as mine didnt. but some 3:42's will last a long time I bet.
Old Aug 18, 2007 | 09:59 AM
BYE RICE's Avatar
If the rear end is set properly..& you used a Motive or Precicision gear set & a girdle,3.73's last alot longer than you might expect.
I sold my original 10 bolt that had been upgraded with all of the parts I just mentioned to a guy whose running an LS2 swap in his 98...It's got LT's,spray & a stall..He cuts at least 1.7's on it & runs 11's .It's been in the car over a year & I dont think he even took the cover off to inspect it when I sold it to him.
Autos just arent as hard as six speeds on driveline parts..
Just never wheel/dry hop.
Old Aug 18, 2007 | 10:31 AM
ive got a 3800stall with 3.73's with the stud kit and girdle. i cut 1.7 60fts consistently but of course i havent got the heads yet. i agree with by rice that on auto's the rear seems to last alot longer.
Old Aug 18, 2007 | 12:59 PM
  #32
oh ok good, im gunna do some lower control arms and panhard bar and relocation brackets when i can. I just got the richmond gear kit so hopfully itll stay together..
Old Aug 18, 2007 | 06:49 PM
  #33
BYE RICE's Avatar
Notice I didn't say Richmonds..
The only times I've ever broken a ring & pinion..It was a Richmond.They are noisey pieces of fragile **** & I avoid them like the plague.
Old Oct 22, 2007 | 06:23 AM
  #34
Thule's Avatar
TheLS1Kid
is your car not flycutted?
this migth be the cam for me!
can anyone paste a link to me where i can check it out?
Old Oct 22, 2007 | 07:27 PM
  #35
big reg's Avatar
Originally Posted by Thule
TheLS1Kid
Here you go bud.
http://www.texas-speed.com/shop/item...d=169&catid=44
Old Oct 25, 2007 | 02:34 PM
  #36
TheLS1Kid's Avatar
TheLS1Kid
No flycutting here. I'm definitely cutting it close though.
I highly recommend for you to measure PTV to make sure.
Old Dec 25, 2007 | 12:14 PM
  #37
ski23's Avatar
Im looking into this cam for my CAM ONLY SS. Full boltons ud pulley with 4.10 rear. Car is not a daily driver, weekend warrior with a few track visits per year. Im leaning towards this cam or the ms3 any suggestions? thanks guys
Old Mar 9, 2008 | 03:03 PM
  #38
ghui99ss's Avatar
im thinking the same, either ms3 or the 233/239, however im probably goin with afr heads. what does every1 else think?
