What are my HP&Torque with my setup?
Old Aug 16, 2007 | 07:14 PM
TA1972's Avatar
Default What are my HP&Torque with my setup?
I want to know what my RWHP&T with my setup that i have. Here's my mods:224/224,581/581,114 cam,LS6 intake,243 non ported heads,yella terra rockers,Prc duals,lid,ported TB,Dynatec LT's with highflow cats,Borla exhaust,LS6 clutch setup. I got my car tuned with Hptuner from a good guy that know and he goes by the name 12secSS. He tuned my car really good. The numbers that he thinks is about 370-380 to the wheels,but I wanted to know what other members RWHP is who have a simular setup like mine. I also wanted to know where my powerband is at which RPM. I never really punched my car to high rpm so I don't really know.Maybe i should. Another thing is that my cam at which rpm max power on these cams? I know this might be of a waste of tread,but wanted to know,because i see that other members #'s are different.
Old Aug 16, 2007 | 07:27 PM
teke184's Avatar
i'd say 380rwhp is a good estimate
with good heads you could easily make over 400rwhp, and if you stick to a small runner you'll make some killer pwer down low
Old Aug 16, 2007 | 07:32 PM
NC98Z's Avatar
No 2 cars are alike. See if anybody that goes to your local dragstrip has a G-tech or whatever or put it on a dyno. Most shops have a shop/dyno day once a year where you can buy a pull for $50. Or you can do it with math. Go to the dragstrip and do your best. After that go the the www.Golenengineservice.com site and use their free drag racing calulators to calulate you HP from your et/mph. Otherwise its gonna cost you.. Are you an A4 or a 6-speed because there is a big difference between the two.
Old Aug 16, 2007 | 07:42 PM
TA1972's Avatar
Mines a M6
Old Aug 16, 2007 | 10:44 PM
allthrotle's Avatar
Im guessing around 400. I made 445rwhp and my cam specs are a little bit bigger, My heads have been ported and they're a 243 casting. I think anywhere from 380-400rwhp.
Old Aug 17, 2007 | 12:06 AM
N4cer's Avatar
Depends on the dyno also.
