lets talk head!!!
Old Aug 17, 2007 | 12:15 PM
regency's Avatar
Default lets talk head!!!
LS1 honed to like a 3.903 or 3.905 somewhere in that area, with a stock head gasket and 241's what would be my CR? i would like to bump the compression up a lil bit and have some better flowing heads at the same time and not get out of the quench area. i was thinking of using a 317 milled .045 and a .045 gasket, would this work or would i loose compression
Old Aug 18, 2007 | 01:39 AM
PREDATOR-Z's Avatar
Using heads that are milled more than .035 will hurt your flow and negate your potential compression gain.
If budget is your game, then mill the 241s .035 and get them ported. However nowadays you can get a set of ported 243s (LS2/LS6) stage 1s (with LS6 springs) for
less than $1000 (flowing ~300cfm intake)
Old Aug 18, 2007 | 02:12 AM
regency's Avatar
how should the LS6 Stage 2.5's perform (2.04 & 1.575)
Old Aug 18, 2007 | 06:40 AM
PREDATOR-Z's Avatar
From who, PRC? (only because they carry stage 2.5 with same valve and your cam is 228r)
Only use 2.04 if they have aftermarket seats. 2.04 on stock 2.02 seats is a sales gimmic, not allowing full potential of bigger valves.
If you have the $$, then the 5.3L PRC with 2.02/1.57 valves will be nice with the 228r
Old Aug 18, 2007 | 11:02 AM
regency's Avatar
i got all this from TSP website
Old Aug 18, 2007 | 12:02 PM
KCS's Avatar
KCS
Moderator
How does milling the cylinder head hurt flow?
Old Aug 18, 2007 | 12:41 PM
PREDATOR-Z's Avatar
Because you are shrouding the valve as you are reducing it surrounding chamber area. This is more true with OEM casting VS let us say AFR because the AFRs have thicker decks and deeper chamber shapes.
This effect is also increased as valve size increases.
Old Aug 18, 2007 | 01:02 PM
KCS's Avatar
KCS
Moderator
Yeah, but in this case isn't the chamber on the 6.0L head is for a 4" bore but going on a 3.900" bore. I don't think .035" mill is enough to shroud the valve anymore that what the bore is going to.
Old Aug 19, 2007 | 05:49 AM
PREDATOR-Z's Avatar
He is milling .050 not .035
Not only that but he might have intake allignment issues.
The proper way to reduce chamber size in 6.0 castings is to weld the chambers and reshape. to desired volume.
