Who has an ARE 436ci stroker motor?????????????
Can you say 10's?I just hope I can get half that, I'd be happy with 20 more.
Thanks
We do have similar set-ups indeed and my MTI motor uses the S1 cam with specs of 244/244, .612 lift and 112 lsa and im running 11:25 to 1 compresion on pump gas but also running an irnblock vs your alum sleeve. 500rwhp your expecting is very difficult to achieve on a big stalled A4 with gears without going solid roller. I would reflash back to stock and get an excellent local ls1 tuner to get you on a dyno and redial you in and i bet you bull 480rwhp (which is about 600 crank) and close to 500rwtq!
Best of luck. Forget the mail order tune with you big investmnet you need to get dialed in live on a dyno by a pro. Jayson at MTI dialed me in and he knows his ****.After my motor gets broken in (only ahs 1600 miles) i bet i see 480rwhp and someting tells me i am running rich fromMTI and may lean out a tad with my MAF T to pick up a few more hidden horsies!
Just give me a ring during the week and we'll get this straight if you're ready for me to fix up his f ups
I asked Ed the other day why my knock sensors picked up all kinds of knock at part throttle, 11 degrees, but doesn't pick up the crazy marble sounds at WOT, he doesn't know, he just said my motor was messed up or something else is wrong. He also told me that he blocked the misfire codes, like you said
He said the light load area of my spark tables are stock and that 26 degrees of timing advance is plenty for my motor.
Later.
He said the light load area of my spark tables are stock and that 26 degrees of timing advance is plenty for my motor. Later.
When I finally gave up on Ed after mucho
and
I had to have my PCM reflashed back to stock and begin all over again. Ed does lock his computers so you'll never be able to tell for sure what he did. Sounds to me like he has de-sensitized you knock sensors to the point of uselessness. The marbles sound like detonation to me and is more than likely a tuning and fuel issue than a hurt motor. If you keep listening to Ed and don't get that that thing tuned soon he will be right about the motor because it will let go.Are there any well known tuners in Fla. that have a wide band and dyno. If noting else strap it down and the wide band will tell you for sure how lean it's running
Good luck, I hope you get it sorted out soon
Paul
Well after a thrown rod and figuring that detonation had something to do with it. I came to the realization that the knock sensors were probably disabled. I had always run alot of juice and always though I was safe since no knock was present. How wrong I was.
After building the new motor I did some testing and concluded the knock sensors must be disabled. Luckily my Ed wright program was old enough it was not locked. I used a local guy , Fasterproms, to go into the program and see what was up. And sure enough he had some parameters off scale that would not allow the sensors to be within a specific window to operate. I believe it was the MAP setting. The values were reversed. We set the valuse so that I would see a max knock retard of 5 degrees and KR would be enabled between X MAP and Y MAP. And whaddya know...damn knock sensors worked.
I also worked on Vinces car. I am convinced his was the same way and caused an early death to his motor as well. I do take some responsability for my motors early death since there were other factors. But detonation and no KR function had a part. Especially when you are looking for KR as a key indicator of engine tune. And I was assured by Ed they were not deleted.
I spend 4 months chasing down a crank position relearn code which no Tech II could get done.
The problem was the ECM he sent me. One new ECM + factory program + LS1 Edit = no problems.
Not only did I have no problems getting the crank position relearn done, the car had LOADS more drivability and no surging/stalling. I didn't get a chance to dyno with the Ed WRight ECM for fear of the CPS code, but the new tune made the old tune feel like I was dragging a parachute behind the car.
At no time during the conversations I had with their shop did they have any doubt that the ECM was fine and the tune was fine.
Thanks for nuttin'. Reading this thread only convinces me more and more that I did the right thing.
Bad30th
This is making this whole journey UN-Fun.
If your really being honest with all of us that started as soon as the pcm was installed and not "well maybe a little later" , it should be cut and dried you got a bad tune. Is it the chicken or the egg????
The oil burn has been bad since I picked the car up in Feb. The rings are set-up for nitrous from what I was told so oil burn is expected. I called Norris Motorsports during that 3 month period to let him know about the oil burn so there's no question when it started, thats why I called him from time-to-time, so there's a record of it. It burned the 1.5 qrts in 320 miles 2 weeks ago. But I've been checking it since then and it's not going at that rate anymore, it's stabilized in the hatch marks on the dip stick. Granted, I'm driving it like my grandma drives. I can handle a qrt every 1,000.
Tomorrow things start to get in order.
bottum line, do a compression check & if everything is okay then put your car on a dyno & see what's going on with your A/F ratio.
oh btw, I have Ed Wright tunning for my 427 & it works great!
This might not be a bad tune at all because the amount of oil consumption you describe is a sure cause of excessive detonation.
Figure out the oil consumption before deciding you've got a bad tune.
