ls1 bore
Old Aug 17, 2007 | 08:03 PM
blackn2oss's Avatar
Default ls1 bore
what is the most u can bore a ls1 and be safe? number 5 went to rich and burnt the outside of the piston and scared the sleave! any help would be great!
Old Aug 17, 2007 | 08:15 PM
blu00rdstr's Avatar
Just a clean-up hone, .005" for the early LS1 blocks. Later LS1 and LS6 blocks had a thicker sleeve, they supposedly can go .010" but not for high-HP use.
Old Aug 17, 2007 | 09:00 PM
blackn2oss's Avatar
all i want is to get the scar out and no more because with my set up im going to be close to 650 rwhp
Old Aug 17, 2007 | 09:52 PM
blu00rdstr's Avatar
The only way to find out is to bring it to a machine shop and get it honed out. They won't know what hone will take the scar out until they hone it.
Old Aug 17, 2007 | 10:37 PM
caviness's Avatar
how much to resleve it for big bore??
Old Aug 18, 2007 | 05:31 PM
blu00rdstr's Avatar
Darton wet sleeves are $2,600 installed at R.E.D., and will require the use of special coolant. Between an LS1 and LS6, the LS1 is the only of the two to sleeve, and wet sleeves are the only reliable sleeving method for the LS1. The LS6 crankcase breathing windows under the cylinders carve out important supporting material for the sleeves, which is why the LS1 is preferred.
For the price and coolant issues involved with an LS1, you may also consider an LS2 dry sleeve which is $1,670 installed at R.E.D., but add to that the cost of the LS2 block and covers. If R.E.D. supplies a new block, the total cost is $2,750. This is what I would do if I had the budget. I'd love a 4.125 bore and 3.622 or 3.26 crank, with caddy racing lifters and Harland Sharp rebuilt rockers, the thing would rev.
Some people are considering resleeving L92/LS3 blocks, but in the L92 the sleeves are not always straight. A few blocks need to be sonic tested to select a good block for resleeving, so if you have a new L92 block it doesn't mean it's good for sleeving.
Add costs of packaging and shipping the blocks around also.
R.E.D. - http://www.raceenginedevelopment.com/
