Can experts, help!
Old Aug 22, 2007 | 11:49 AM
twospeed's Avatar
Default Can experts, help!
I need advice on this cam. I would like to install this as a cam only for the time being. Cam specs 228/230, .585 .585 112+4. This is the Tric-flo cam. The car is an 02' m6 vette, Ported T/B, de screened MAF, T/B bi-pass? Borla XR-1 cat back, Kooks LTs custom tune by Formato. I will use Isky bee hive tool room springs ( afraid of Comps 918s with all the issues they've been having) and go with Comp pro-magnum rockers. Has any one run this as a cam only? What can I expect as far as driveability? What about HP? The car was making 330 before the Kooks LTs Do you think I will be at 400 or more? Thanks in advance
Old Aug 23, 2007 | 09:14 AM
twospeed's Avatar
Not one response? Come on guys
Old Aug 24, 2007 | 04:56 PM
JPH's Avatar
JPH
1. use a dual spring. crane #144832 or comp #26921.
2. don't waste your money on rockers.
3. cam works awesome. expect big gains from 3000-6500. pulls hard up top.
4. find a good tuner, and driveabilly will be good. a4 cars need 3000+ stall to work right, and expect minor low speed issues now and then.
5. 400+hp and 380+trq in m6 car.
hope this helps man.
