Is this block repairable??
Old Aug 22, 2007 | 12:50 PM
zo6freak's Avatar
Default Is this block repairable??
This is a 2000 LS1 out of a vette that had 15000 miles on it before the motor hydrolocked. Is this block repairable? The hole is less than an inch in diameter.
Thanks!!
Old Aug 22, 2007 | 01:33 PM
Bryan @ Speed Inc.'s Avatar
wow - i do not think that's repairable. you need to weld or somehow mend that hole, and then you need a new cylinder sleeve.
that'll be a lot of money just to MAYBE get it repaired.
yikes - that sucks.
Old Aug 22, 2007 | 01:38 PM
gonbad's Avatar
I agree - I doubt that is repairable. You can get a used LS1/6 block for around $500 or less.
Old Aug 22, 2007 | 01:45 PM
Kamin's Avatar
you cant fix a hole in a block.
Old Aug 22, 2007 | 01:50 PM
WickEdSix98's Avatar
On an aluminum block you can, but the deciding factor is what the inside looks like. Most likely its cheaper to buy another stock block.
