should i replace my timing chain
Old Aug 24, 2007 | 07:39 AM
98Camarod's Avatar
I can assure you all, that the Rollmaster Double chain and Melling 295 oil pump do not work together. I had the gear on all the way, I used the spacers, everything was done right. The bitch still rubbed.
Old Aug 24, 2007 | 08:57 AM
litle88's Avatar
Originally Posted by RunNE1
I just purchased the LS2 timing chain for my cam replacement install. For some reason, my local dealer charged me 48.00 for the 35.00 part. Must be the Corvette tax.
Thats why I never buy **** from those thieves!
If you call other dealers you will see that they all have different prices!
Take that **** back and buy one of the sponsors. All 80% of my mods I got at speedinc! and all from the sponsors.
Just my 02 cents though.
You made a good choice to upgrade though,dont forget to upgrade your oil pump since your going in there, I got a melling and kept the high pressure spring in it. I luv the extra volume and pressure.
Also you should upgrade those week pushrods for some chromoly, their less than 100 bux.
Old Aug 24, 2007 | 10:54 AM
mr. Jones's Avatar
my rollmaster was with the stock oil pump.
So melling and rollmaster don't fit
Old Aug 24, 2007 | 01:20 PM
99DWPTA's Avatar
i just ordered a ls2 timing chain from stealership. 54$
gayyyyy
anyways.
what oil pump?
can i do a stock ls6 oil pump. or??? which one will fit the ls2 chani or w/e???
i dont have alot of money and i'd like to spend around 140$ max on a oil pump
