oil question
Old Aug 23, 2007 | 12:52 AM
the SS show's Avatar
Default oil question
i know some Ls1s burn oil but how much? mine is going through a quart about every 500 miles. im running ams oil and this is getting expensive..
Old Aug 23, 2007 | 01:04 AM
SSDude's Avatar
About 1 quart every three thousand miles is considered normal. Your situation is excessive. You need to find out what's wrong.
Old Aug 23, 2007 | 01:50 AM
Tainted's Avatar
check into your pcv system and if it checks out fine time for a compression test
Old Sep 5, 2007 | 12:37 PM
thanks for the help but the solution was simple. i bought a new dipstick cause the old one was rather hard to read. turns out the new one was almost an inch shorter than the factory one. i thought i had burned a bunch of oil but wasnt. just assumed both dipsticks were the same length. i guess thats what you get when parts are made in china..
