Question about heads
Old Aug 23, 2007 | 11:10 PM
ws6_bandit's Avatar
Default Question about heads
Im doing a H/C swap soon and im lookn at the stage II LS6 heads and the tr 230 cam. they have the heads in a 59cc and a 64cc. Im kinda a noobie to this maybe someone could explain to me what different size combustion chambers do and which would be best. thanks
Old Aug 24, 2007 | 08:04 AM
Gunnar@Patriot's Avatar
The different size combustion chambers change your compression ratio. The smaller the chamber, the higher the compression. A 64cc chamber on a stock LS1 will give you 10.5-10.7 compression depending on the gasket and a 59cc will give you 11-11.3 depending on the gasket.
