which do I need
Old Aug 24, 2007 | 11:39 AM
camross998's Avatar
Default which do I need
I just got a LS6 intake I have a 1998 Z28 A4 which of these coolant lines i need to make the ls6intake mount down on top of the vally cover LS1/LS6 coolant pipe (01-02) (need for installing LS6 intake manifold) = 12568478
LS1/LS6 coolant plug (01-02) (need 2) (need for installing LS6 intake manifold) = 12562788 because I got some people tellin me i can you the stock ls1 coolant line but i got to grained the back part of the LS6 intake wich is it thanks or is it both of them I need?
Old Aug 24, 2007 | 12:00 PM
Evans752's Avatar
I went though the same thing a couple of years ago and I am pretty sure but not possitive you can use the stock cooling line but you have to cut on the intake unerneath to clear and I wouldnt I d just buy the right stuff to make it work. Just call or go to dealer and tell them you have a 2002 camaro and ask for the plugs and cooling line for the front. Good luck
Old Aug 24, 2007 | 01:03 PM
68birdls1's Avatar
You dont have to cut anything, just take down the fins on the bottom of the intake where the coollant lines go and you will be set.
