Can someone explain a collapsed Lifter?
Collapsed is when the lifter won't pump up. I've had a few flat tappet lifters do this.
They don't recover because they fail. Something breaks or blocks the proportioning valve.
The reason your lifters recovered from floating is because floating a lifter is something totally different that is a result of a weak spring and not lifter failure.
Floating and collapsing a lifter are apples and oranges and can not be compared. To try and compare them by wanting to know why one recoved and the ohter didn't is like comparing an engine that bent a push rod to one that threw a rod.
The reason why you don't see collpased lifters with Gen 1&2 engines is that people usually change the lifters when changing the cam. Gen 3 you have to remove the heads to do this so most don't change them. Because of this, stock Gen 1&2 lifters also don't see the higher RPM, and lifts that Gen 3's tend to see. Look at the big a$$ cams people are putting in their cam only LS1's w/stock lifters.
That said, I have had flat tappet lifters collapse in a 350 and they were designed for the cam and valves I used.
