bent push rod?????
Old Aug 30, 2007 | 08:28 PM
z2fast8's Avatar
Default bent push rod?????
ok my car runs fine untill it gets warm then starts cut'n out and runing bad could this be a bent pushrod or a valve not seating?
Old Aug 31, 2007 | 11:17 AM
nitroushane's Avatar
Have you check the compression or ran a leak down test on your car?
Old Aug 31, 2007 | 12:01 PM
Ericbigmac83's Avatar
not really, youre gonna get a constant ticking with a bent pushrod
Old Aug 31, 2007 | 01:10 PM
N4cer's Avatar
IAT sensor?
Old Aug 31, 2007 | 01:18 PM
5.3LJimmy's Avatar
A bent pushrod or leaky valve wouldn't run good cold either. It could be a bad sensor that doesn't affect anything until the pcm goes into closed loop operation.
Old Aug 31, 2007 | 05:36 PM
z2fast8's Avatar
Iat??
Old Aug 31, 2007 | 05:42 PM
Intake Air Temperature
Old Aug 31, 2007 | 07:01 PM
socmguy's Avatar
Restricted User
make sure all your vacuum lines are in good shape and check your IAC(idle air control) sensor on your throttle body above your TPS sensor.
 Michael S. Palmer
Old Aug 31, 2007 | 09:41 PM
thosewhohatedmecreat's Avatar
IAC motor, not sensor
lol just being a smart ***
