New melling oil pump full of grease
Old Sep 1, 2007 | 07:18 AM
theblur98ss's Avatar
Default New melling oil pump full of grease
Just got a new melling oil pump and it's full of some white grease. Should I clean that out before startup or leave it in there. I've heard on the older sbc's to pack the pumps with grease.
Old Sep 1, 2007 | 09:39 AM
JPH's Avatar
JPH
i clean them, usually engine assembly oil on gears and prime motor and go.
Old Sep 1, 2007 | 01:07 PM
Beast96Z's Avatar
The grease is there to reduce start up friction. You can clean out what you can get to, but I wouldn't worry to much with it. It'll come out in the oil change.
Old Sep 1, 2007 | 01:40 PM
Tom@SpeedInc's Avatar
we pack ours with Lithium grease when installing.
Old Sep 1, 2007 | 08:32 PM
gollum's Avatar
The grease is there for quick oil pump priming during start up...leave it.
Old Sep 5, 2007 | 09:51 AM
radkon's Avatar
+1 it helps lubricate the pump and build vacuum while the oil system is dry don't remove it!
