Easy way to install lifters...
Old May 29, 2003 | 04:46 PM
robertbartsch's Avatar
Default Easy way to install lifters...
My old lifters and plastic lifter holders are out of the car....
I assume the best way to re-install them is to insert all four lifters in the plastic holder and push them in the block together (4 at a time) into the lifter bores; then bolt down the plastic holder..
Is this correct?
Old May 29, 2003 | 04:57 PM
jmX's Avatar
jmX
Default Re: Easy way to install lifters...
Dunno if its the easiest but that is the way I've always done it.
Old May 29, 2003 | 05:52 PM
2001CamaroGuy's Avatar
thats how I did it......seemed to be the only way it could be done.
Chris
Old May 30, 2003 | 09:39 AM
Constrictor 98TA's Avatar
I put my lifters in the engine one at a time, and then put the lifter cup over it. I did that to all 16 of them and had no problems. What difference would it make if the lifters go in before the cup or with it?
Old May 30, 2003 | 09:56 AM
Vents's Avatar
i usually pull the heads off first.
but that method of putting in four at a time seems to be the easiest.
Old May 30, 2003 | 11:14 AM
Constrictor:
I have not worked with roller lifters that have these plastic holders before, so I was concerned that the lifter roller tip would not align properly with the cam lobes and plastic holder cups if I put them in one-at-a-time....
If you installed the lifter one at a time, I assume they aligned correctly with the cam and plastic holders and it worked.
I was not sure it would....
Thanks...
