Heads and Cam
Old Sep 9, 2007 | 12:21 AM
purplehays4's Avatar
Default Heads and Cam
Hey Guys Im really wantin to pump out more power from the T/A and thinking about getting heads and cam. What would you all suggest doing??
I want a pretty mild cam that will have a nice lope to it when idlein. What are some specs I should look for? I want to try and be pushing 350-400 at the wheels once I get done. Any Idea's??
I have heard of some people going with the 5.3 heads on the new Vortec motors?? Why?? What is the best set of heads for a buget car??
What all else should I be looking into besides the heads and cam?? Keep in mind that im still paying off the car but still have some money to play with. I want a winter project! haha
Thanks in advance
Old Sep 9, 2007 | 12:35 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Moving to Internal
Old Sep 9, 2007 | 01:28 AM
Oh my bad, Thanks I just seen where it said LS1 motors, Sorry
Old Sep 9, 2007 | 02:13 AM
danf1000's Avatar
For the LS-series engines the 5.3 heads offer finished intake and exhaust port that is smaller than LS6 CNC'd heads for a lower rpm, more torquey engine disposition. The combustion chamber is smaller as well, contributing to a higher static compression ratio. CNC'd GM castings can start at around $1000. also, check out the non-GM castings from AFR, Edelbrock, TFS, Dart, etc.... that add efficiency.
Cam options for lopey idle would include a 114 or less lobe separation angle. Smaller street cams would have a 112 or less. A duration of greater than 230 degrees with an LSA of 112 would necessitate advanced tuning.
Other parts to consider are: head bolts, timing set, springs, pushrods, gasket set, and maybe an oil pump and tuning software
For this level, possible additions are clutch, fuel pump, and fuel injectors
Old Sep 9, 2007 | 12:48 PM
Well I just put a brand new LS7 clutch kit in it, so I should be good there.
So are the 5.3 heads a good idea to go with? What about the 6.0 heads?? Why do people use them for?? See Im really new to these LS engines and dont have a clue on how to kick out some power at a decent price. Anything helps.
Thanks
