98 LS1 rear cover ?
Old Sep 10, 2007 | 07:28 PM
oange ss's Avatar
Default 98 LS1 rear cover ?
can i use an 99+ rear cover gasket on a 98 LS1 motor ? i know they're different, but enough to have to use the 98 gasket ? thanx
Old Sep 10, 2007 | 07:36 PM
theblur98ss's Avatar
I've used my 98 cover on the newer blocks with no problems. The 98 is actually a heavier made cover if you ask me.
Old Sep 10, 2007 | 07:38 PM
oange ss's Avatar
other way around, have 98 block and cover, want to know if i can use the 99+ gasket...thanx for the reply
Old Sep 10, 2007 | 11:08 PM
N2DP2QT's Avatar
i don't see why not. i have a 98 tore down at the moment and called myself looking it over pretty good and didn't see any reason why u couldn't swap back and forth.
Old Sep 11, 2007 | 09:45 AM
oange ss's Avatar
did the original gasket have 2 separate holes or 1 long one ?
Old Sep 11, 2007 | 10:05 AM
bczee's Avatar
Why not run down to the local deal and ask to compare both ?
Can you modify the gasket ?
Old Sep 11, 2007 | 10:33 AM
ls1290's Avatar
Dumb Ass Vette Moderator
I would not modify the gasket. They are cheap enough, so get the correct one.
Keith
