psi for leak down test ?
Old Sep 11, 2007 | 06:30 PM
oange ss's Avatar
Default psi for leak down test ?
did a leak down test on a used motor I got, used 90 psi, is that enough for a leak test ?....reason i ask is the results were 2-3% on all cylinders, this motor is clean but i cant see it being in that good of shape...thanx......
Old Sep 11, 2007 | 06:34 PM
brad8266's Avatar
90 psi is plenty, you have a healthy motor.
Old Sep 11, 2007 | 06:49 PM
oange ss's Avatar
so far then, will do compression test next..fwiw test was done on an engine stand, cold obviously.....thanx for the reply
