How long is it safe to drive H/C untuned?
Old Sep 13, 2007 | 11:01 PM
Louie83's Avatar
Default How long is it safe to drive H/C untuned?
Just trying to figure out if I can drive it home and then drive it to the shop to get it tuned, or should I try and get it towed to the shop?
It would be about 30 minutes of drive time.
Old Sep 13, 2007 | 11:14 PM
Top Fuel's Avatar
yeah you can drive it untuned, might be a little rough depending on how big your cam is, but it'll be alright. Now if your swapping to larger injectors DO NOT drive it until it is tuned.
Steve
Old Sep 13, 2007 | 11:21 PM
ApexVIII's Avatar
yea i would say that you could drive to the shop, it just wont run to hit
Old Sep 13, 2007 | 11:22 PM
Louie83's Avatar
The cam is 230/234 and I have swapped to 30# SVO's, which if I remember correctly, should flow around 36# on an LS1.
So I should not drive it due to the injectors?
Old Sep 14, 2007 | 12:27 AM
SweeTbone's Avatar
Nope. Don't drive with those injectors. Depending on who you have tune it, you can mail/take your PCM to them and they can do some adjustments on it to make it safe and to get you moving. Once they set everything up, you can drive your car there for the final tweaking/dyno tune.
Old Sep 14, 2007 | 12:34 AM
rocksws6's Avatar
Its just going to run really rich. As long as you can get it movin it should be fine. I've had to drive with larger injectors before my tune before. It ran like **** no doubt but I could drive it. I would say drive it around your house or wherever for a little bit and see what its going to do and decide from there. I just couldn't get into the throttle very much or it would start missing but I could cruise and run the speed limit without problem. I think I had every car I've ever wanted to race mess with me in that little drive too.
Old Sep 14, 2007 | 11:20 AM
1LoudTA's Avatar
id say find someoen to at least dial in the injectors for you to get it to the shop, or get to the place where ur having it tuned and swap the new injectors in in their parkinglot if they are okay with it.. shouldnt take more than 20 minutes tops
