is it save for me to drive untuned,
Old Sep 14, 2007 | 12:41 PM
Thule's Avatar
Default is it save for me to drive untuned,
just installed my motor,
along with other parts i got
StageII ls6 heads, 59cc
226/226 585 112LSA cam
FAST90
NW90
FAST fuel rails
85mm GM maf
egr delete
air pump delete,
i am still using the 28lb's injectors,
i know it is not vice to drive it to much,
but while i am still waitiong for my hptuners to arrive,
is it save for me to drive the car? its seems to run fine and puts down alot of power,
i am talking about driving for testin mostly, not dayle drive
it seems to run realy rich..
Old Sep 14, 2007 | 12:55 PM
hammertime's Avatar
I'm not sure what you mean by testing, but the general rule is driving is ok, especially with smaller cams. No WOT though because running it lean under a load is a big no-no.
Also, since you've eliminated the egr and air pump, plus running the FAST and ported heads, you should be getting quite a bit more air, and little more fuel. I definitely wouldn't push it - just not worth the chance.
Old Sep 14, 2007 | 01:00 PM
Furious_George's Avatar
yup what MC hammertime said, just keep your RPMs low and don't drive it that much and you should be fine. should pack a nice little punch when you get her tuned.
Old Sep 14, 2007 | 11:05 PM
Thule's Avatar
i've spin it a little bit.. but not much at all.. only driven it about 20-30 miles
Old Sep 15, 2007 | 03:41 AM
2000Hawk's Avatar
As long as you drive it easy you should be fine, just don't get on it without a tune. When i installed my MS3 turns out my A/F wasn't to bad, it was pretty close to where it is now. But its better to play it safe till all the proper settings are set in.
-Joel
Old Sep 15, 2007 | 05:40 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I drove my 222/226 and 228/232 untuned with worked 241 castings milled .030. If you swap injectors that is when you will most likely start running into problems. If you take it easy I would say your ok. Your duty cycle on the stockers just moved up a notch though. lol I can tell you that!
Old Sep 15, 2007 | 09:56 AM
Websy21's Avatar
I say you are gonna be fine too but take it easy, no WOT. I agree on the injectors but not exactly sure when they max out at, guys? I know most get a minimum of svo 30#(rated 36#). Your stock fuel pump is fine but duty cycle will def be high.
