ls2 timing chain questions
Old Sep 15, 2007 | 02:40 AM
99DWPTA's Avatar
Default ls2 timing chain questions
when putting a ls2 chain on a ls1 motor. do you have to use ls2 gears aswell?
Old Sep 15, 2007 | 03:25 AM
2000Hawk's Avatar
No i used my factory LS1 gears, just align the dots and you'll be set.
-Joel
Old Sep 15, 2007 | 09:48 PM
99DWPTA's Avatar
well i put the chain on and it was very loose.. what would cause this. the dots appeared to be ligned up
Old Sep 15, 2007 | 09:50 PM
99DWPTA's Avatar
even if the dots arnt lined up correctly would that make a diffrence on how loose the chain is?? my factory chain looked loose aswell but not as loose as the ls2 chain i threw on there
Old Sep 16, 2007 | 04:56 AM
deadmanTA's Avatar
I just put my ls2 chain on yesterday and it was loose also, just not quite as bad as the stock one w/ only 25k miles on it.
