Ideal Quench Height for NA Motor?
Old Sep 15, 2007 | 07:06 PM
big thumper122's Avatar
Default Ideal Quench Height for NA Motor?
I've heard ~.035 is ideal, what do you guys think?
Old Sep 16, 2007 | 01:10 AM
brad8266's Avatar
Thats a good spot for a stock bottom end motor. A set of .040 head gaskets will get you close to there.
Old Sep 16, 2007 | 07:36 AM
PREDATOR-Z's Avatar
.035>.045
Old Sep 16, 2007 | 09:06 AM
N4cer's Avatar
.035 is greater than .045? Care to explain? I'm building a 408 now and haven't ordered my head gaskets yet because I'm waiting to make sure how far the pistons stick out of the hole. I am thinking if it's the typical .006-.008, I'll go with a Cometic .040. Is that too little quench?
Old Sep 16, 2007 | 10:58 AM
PREDATOR-Z's Avatar
.035 to .045
Old Sep 16, 2007 | 11:55 AM
vettenuts's Avatar
From the stock 0.051" gaskets to 0.040", what exactly is to be gained?
Old Sep 16, 2007 | 01:45 PM
04gtod's Avatar
My pistons are .007 above the deck. I used .040 cometics. That gives me a .033 quench. Tight quench helps stop detonation and causes better burn in the chamber.
Have run and raced this setup fro 8000 miles, no problems.
