Pushrod Length
Old Sep 17, 2007 | 08:30 AM
RDY2RUN's Avatar
Default Pushrod Length
I currently have an Ls6 cam and pushrods and am upgrading to an F-13 cam. My question is should I use the stock legnth pushrods or the slightly longer Ls6 pushrods? Any help would be appreciated.
Old Oct 1, 2007 | 09:42 PM
mrhzk35404's Avatar
I would like to know this also.
Old Oct 1, 2007 | 11:28 PM
krwyellowZ28's Avatar
X3 on wanting to know. I've been hesitant to install my '04 LS6 cam because of this. I have a set of 7.45" Trick Flow's. . . is this the correct length?
Old Oct 2, 2007 | 09:17 PM
ISeeRed's Avatar
I don't know what length you will need, but the LS6 pushrods aren't longer the valves are. From the smaller base circle and the stock length valves of your head, I would think 7.425" but to be sure you need to use a pushrod length checker.
Old Oct 3, 2007 | 02:14 AM
jegten's Avatar
+1 on the pushrod length checker.
Old Oct 3, 2007 | 10:33 PM
mrhzk35404's Avatar
Ok, I sent Allan at futral an email and he said this "If stock heads\valves, you will need 7.425" length pushrods." This is for the std lift f-13.
Old Oct 3, 2007 | 10:40 PM
Evans752's Avatar
7.40 here with my F13 cam The looser you can have your valve train in your car the faster your car will run. Good Luck
