what size threaded rod to use to pull damper back on?
Old Sep 22, 2007 | 02:14 PM
mvvette97's Avatar
Default what size threaded rod to use to pull damper back on?
I have read that it's best to use a threaded rod and a nut to pull the damper back on but what size is it?
Old Sep 22, 2007 | 02:28 PM
MeentSS02's Avatar
Kleeborp the Moderator™
I'm pretty sure it is an M16x2.0...you should try to get your hands on a thrust washer if you can too. You'll get some serious metal-on-metal grinding otherwise...
Old Sep 22, 2007 | 02:30 PM
mvvette97's Avatar
Cool. I was gunna buy one from that guy on the forum but I need it tomarrow so I'm going to have to make my own.
Old Sep 22, 2007 | 02:32 PM
nofearracing28's Avatar
i got one marc
Old Sep 22, 2007 | 02:40 PM
Dragkid1917's Avatar
i think arp sells a longer crank bolt, it maks thigs 10 times easier
Old Sep 22, 2007 | 06:20 PM
oange ss's Avatar
16 mm x 2mm
Old Sep 22, 2007 | 06:24 PM
MeentSS02's Avatar
Originally Posted by oange ss
16 mm x 2mm
Yes...this is correct...not the M16x1.5 as stated above. I'll change that so it doesn't screw anyone else up.
