Oil Leak, need quick thoughts
Old Sep 24, 2007 | 06:27 AM
Superman09's Avatar
LS1Tech Sponsor
Default Oil Leak, need quick thoughts
Hello, well i noticed an oil leak the other night. I had my timing cover and crank pulley off only maybe 100 miles ago if that to swap crank pulleys back to stock. Anyways, after initial driving after that i noticed a small leak and thought it might be oil from the k-member just dripping out. I have oil return going into my timing cover so thought some might have splashed out into K on removal. Anyway a few nights ago after driving i noticed a leak. I jacked the car up and its dripping off of my sway bar. After jacking it up, some oil dripped down the oil pan due to the new incline. Anyways, appears to be some oil on the bottom 2 bolts of the oil pan by timing cover, and appears to be some on the inside of the crank pulley. So what do you guys thing? Front main seal? Balancer seal? Maybe the crank just needs to be re-tightened? Something worse? Thanks
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
