241 milling
Old Sep 24, 2007 | 08:27 PM
bryced1's Avatar
Default 241 milling
hey im interested in milling my set of stock 241's down a few thousanths. how much could i mill them down, and how much would it raise the compresion?
Old Sep 25, 2007 | 07:44 AM
Gunnar@Patriot's Avatar
.006" is going to equal 1cc of material. It takes about 6cc to equal 1 point in compression. So if you wanted to go up to say 10.5-1, you will need to mill approx. .018". One thing to keep in mind when milling is your PTV clearance with aftermarket cams.
Old Sep 25, 2007 | 10:39 AM
bryced1's Avatar
ive got a .588 lift cam and im using a .040 head gasket. whats the most i can safley mill off?
Old Sep 25, 2007 | 12:01 PM
Dragkid1917's Avatar
whats the stock head gasket thickness. And, can anyone tell me the chamber volume and stuff so i can go to a calculatr online and figure out stuff and wat milling does to raise compression
Old Sep 25, 2007 | 12:12 PM
FDLS1's Avatar
I have 241 heads milled 0.030, a 0.040 cometic gasket, with a Futral F6 226/230 .575/.595 112lsa. Hope this helps.
Old Sep 25, 2007 | 12:25 PM
ok whats the stock gasket size thoo!!!!
Old Sep 25, 2007 | 12:44 PM
FDLS1's Avatar
0.054 stock gasket
