realy wierd question. please help
Old Sep 26, 2007 | 04:42 PM
Big Bird WS6's Avatar
Default realy wierd question. please help
i have a 100% stock block. i am boosting it. repalcing the head bolts and gaskets and some other stuff.
any way question is. if i go from a .051 factor gasket to a .060 cemetic gasket. how much does my compression change?
Old Sep 26, 2007 | 08:43 PM
to the top. please help
Old Sep 29, 2007 | 05:27 PM
any one please.
Old Sep 30, 2007 | 03:46 AM
seawolf18's Avatar
By boosting it you mean adding a super\turbo charger, then I think you would get better results in the Forced Induction section.
Old Sep 30, 2007 | 03:04 PM
deadmanTA's Avatar
If you are wanting to lower your CR then just run a set of 6.0 317 heads. They will lower the CR to a more boost friendly 9.4-9.5. You usually pick a set up on here for $250-350.
