6.125 rods and compression
Old Jun 4, 2003 | 07:06 PM
h53speed's Avatar
Default 6.125 rods and compression
Just curious if using these rods and the diamond -2 pistons would increase my compression any. Hopefully not. 5.3 heads milled .015 and block decked .002-.003. That should put me in the 11.2 range correct with a stock thickness head gasket. Thanks.
-Wes
Old Jun 4, 2003 | 11:39 PM
Hawk's Avatar
Default Re: 6.125 rods and compression
It lowers it a bit because of the valve reliefs cut into the pistons. I did the pro mod rods they are sweet with diamond pistons. chris @ diamond or jason at thunder could hook you up. Longer connecting rod has the pin slightly higher in the piston.
