More Torque?
SLP Lid
SLP MAF
!A.I.R.
Relocated IAT sensor
Ported/Polished 241 heads
232/238 .595/.605 112LSA XE-R cam
QTP headers
Pacesetter ORYP
Factory CME exhaust w/ Magnaflow muffler
3.73 Gears
Harlan Shiftlight
Custom Tune w/ EFI Live
LS7 Clutch & LS2 Flywheel
Were the heads milled at all? What head gaskets did you use? Of course the problem will be with that duration you will most likley have to flycut to maximize your DCR (mill the heads and .040 gasket if you have not already). On the flip side you will gain tq and consequently Hp EVERYWHERE. An easier option may be to advance the camshaft a couple of degrees, this will shift your entire power curve down a little and will most likely result in more tq and it will come in sooner, but your peak HP will most likely stay the same.
