228/232 .588/.595 110+? Lsa
Old Oct 4, 2007 | 06:42 PM
TORCHD 02 TA's Avatar
Originally Posted by NoMoreFWD
Wrong again.
a 106 ICL is much tighter than a 110 ICL
Prove me wrong. ask any tuner
Old Oct 4, 2007 | 06:51 PM
rosey's Avatar
Um
Do you even know what ICL means?
Old Oct 4, 2007 | 06:52 PM
Originally Posted by rosey
Um
UMMMMM Intake Center Line
that and the amount of overlap a cam has makes it hard to tune
Old Oct 4, 2007 | 06:55 PM
rosey's Avatar
Well, guess that proves you know how to use google. Too bad you have no idea what it actually means.
Old Oct 4, 2007 | 07:03 PM
yeah i used google for ICL same thing for VE, IVO, IVC, EVO, EVC, DCR, SCR, BTDC, ATDC, ABDC, and BBDC
i have no idea what any of that means............
Old Oct 4, 2007 | 07:12 PM
rosey's Avatar
Wow, what an astonishing ability you have to name a bunch of irrelevant acronyms and repeat exactly what I just said.
Good thing ls1tech has you around, this forum would collapse without all 2859 of your knowledgeable and insightful posts.
Old Oct 4, 2007 | 07:33 PM
CAMAROZ28AQUINO's Avatar
Sorry, i miss typed, the further that it is advanced the RPMs are moved down.. Sorry about the mis info. Yes my car is a dawg below 2500 RPMs. i need to get gears and some heads. i am still on the stock ones. Here is my cam graph
And yes Being on a 110 +4 makes it harder to tune. LSA is mu8ch tighter than a straight up 110.
what gears u runnin, 3.42's? i have 3.73's...i wonder if it will feel like a dog for me with a 3000 stall too?
Old Oct 4, 2007 | 07:53 PM
NoMoreFWD's Avatar
You're previous post stated LSA, which is ground into the cam and doesn't change. Now your saying ICL, two different things.
Old Oct 5, 2007 | 07:08 AM
I am running stock 3.42s. 4.10s for me would wake my car up under 2500 RPMs.
dunno about you, i dont know anyhting about stalls
Old Oct 5, 2007 | 10:03 AM
04gtod's Avatar
Lobe separation angle, duration, lift, and intake centerline are all ground in to the cam. the only one you can change is th ICL by advancing or retarding the cam with an adjustable timing gear set. Example: by advancing the cam 4 degrees the intake and exhaust events both start 4 degrees earlier so the LSA STAYS THE SAME!!
Old Oct 5, 2007 | 01:48 PM
hammertime's Avatar
10 degrees of overlap should not be a big challenge to tune. The popular G5X3 cam is 234/242 112+4. That cam has 14 degrees overlap and a 108 ICL, and lots of people are DD'ing it without much problem.
Your car needs more Static compression to come alive on the low end, otherwise, perhaps your tuner just isn't up to the job. It's not to difficult to get a good peak number to show everyone, but a lot more time goes into the drivability tune.
And I'm not saying your tuner didn't spend the time, but perhaps it wasn't time well spent.
Old Oct 6, 2007 | 09:25 AM
  #32
NoMoreFWD's Avatar
How can ICL be ground in and yet changeable. Chose one or the other.
Old Oct 6, 2007 | 09:28 AM
  #33
NoMoreFWD's Avatar
I agree that this cam with 10 deg of overlap, isn't that hard to tune.
Old Oct 6, 2007 | 10:21 AM
  #34
PREDATOR-Z's Avatar
NoMore, 04gtod is correct. By advancing or retarding the cam you alter the valve events and the ICL. While it is the same in the grind, in application it becomes altered. That is called degreing a cam.
Old Oct 6, 2007 | 12:25 PM
  #35
04gtod's Avatar
Thanks Predator Z, I tried to be as simple as clear as I could be in my explanation.
Old Oct 6, 2007 | 04:37 PM
  #36
BOWTIE's Avatar
The ICL is ground into the cam when it is ground, and for reasons I am not sure of is always relative to the LSA (i.e. a 227/234 .640/.598 112 camshaft will have a LSA of 112 degrees and will be installed with the ICL at 112, then if it is followed with a +2,+4 then it would be ground with that amount of advance giving it an ICL of 110,108 respectively). All the ICL really is the relationship between the center of the intake lobe and the crankshaft. The ground in ICL is determined by where they grind the cam in relation to the cam dowel and timing gear mounting bolts. This can be easily altered by installing an adjustable timing set and either rotating the camshaft to advance or retard the valve events in relation to the crankshaft/pistons. To make it simple, it is originally ground in, but can also be altered with an adjustable gear set. The LSA, however, can not be altered in a single camshaft application.
Old Oct 6, 2007 | 05:24 PM
  #37
DAVESS02's Avatar
My 228/230 xer is on 110 +1 and its a bit doggy down low, M6 BTW. Pulls good on top. Also, I'm running a ported FAST 90/90 and AFR 225 small bores. I knew I'd be giving some up down low but I've been planning a 400+ci short block for the spring so I just bought once rather than having to swap heads, etc.
Old Oct 7, 2007 | 10:30 AM
  #38
what gears you running? I need to know if mine will feel dogish down low because if it does i dont want the cam
Old Oct 7, 2007 | 10:57 AM
  #39
PREDATOR-Z's Avatar
quote= what gears you running? I need to know if mine will feel dogish down low because if it does i dont want the cam
camaroz28aquino> His bigger heads 225cc with 90/90 is where he lost a bit of trq down low.
You have none of that and a stalled A4, with a good tune you'll fry your tires and that is not dogish by any means.
That is a good cam for your setup
Old Oct 7, 2007 | 11:57 AM
  #40
DAVESS02's Avatar
Yea, aquino, plus you're looking at advancing your grind +2.
