Mahle Pistons
They are for a 3.905 bore and a 3.622 stroke which is what I am currently running but I was wondering if you could use a 4.0 or 4.1 stroker crank with the pistons?
You could do a 4.100 stroke, but you would have to go to a 5.85" rod from someone like Eagle, and you would have to have the pin end honed to accept the .945 wrist pin, (they might have to replace the bushing to do it) and that's assuming that the rod isn't too wide to fit between the pin bosses on the piston. That would put the pistons about .010" down in the hole which isn't ideal, but it's not the end of the world. That is assuming that your pistons have a compression height of 1.340 and a block deck height of ~9.25".
In the end, it would be easier for you to sell your pistons and buy what you need.
If you guys are talking about that bullshit rod/stroke ratio, and "side loading" of the block, those are the biggest internet myths in the world. Hell, if it mattered, the old Gen I 400's would have been oil buring beasts, and we all know they just leaked.....lol.
A comparison, LS1 with a 5.85 rod with 4.100 stroke equals 1.426 r/s ratio. Gen I 400 sb with a factory 5.565 rod and a factory 3.75 stroke equals 1.484 r/s ratio. Not much difference huh?
Oh, and the shorter rod engine is going to be less detonation prone than the long rod, especially if it's a power adder vehicle too.
